Howto view streams in HA from a Dahua camera system during events?
Hi
EDIT: maybe my question was to much in 1 thread (howto configure and popup a stream at certain events); therefore changed it.
I have tried different integrations but no success at all.
The goal is to be able to see a stream in HA for some time after an alarm trigger (which is a HA switch).
It’s a Dahua IP-system and I already managed to use the RTSP streams, directly from the NVR, and display them on RPi’s but just to use as a monitor, so no interaction.
Any help/ideas are highly appreciated!
Nick
bump
Anybody?
Have you tryed MotionEye ?
Hi ukro, thanks for your reply.
As a coincidence, last week the NVR broke down and since I already played a little with MotionEye & ZoneMinder a long time ago and had the ZoneMinder container still on my server, I dusted that one off.
I succeeded with the picture-entity card to get a still image every 10s and when I click on it, I get a live view: this works very well.
The next step would be to get a notification in HA.
Notification for movement detection?
So this is in MotionEye…
I didn’t come to that point yet to see how I could use the motion triggers in HA but at first sight, MotionEye seems to have an advantage to achieve this.
Since the motion notifications are off in your picture: how are you using MotionEye and is there a connection to HA?
I didn’t set it up yet, nevertheless there is an option/
Connection to HA, yes through add-on see pic
