Hoymiles DTU-Lite auslesen
Hi there,
I’m using a homilies dtu-lite-s Stick and atm the hoymiles cloud (would be nice, if I could avoid this).
Which is the right add-on, to read out the data local out of the DTU?
Or isn’t that possible? And if it isn’t… how to read out the data out of the cloud?
I also tried hoymiles-dtu-homeassistant-addon. But couldn’t find any entity… So where can I find there data?
Kind regards!
I have dtu lite as well and my setup is wprking with GitHub - dmslabsbr/hoymiles: Hoymiles ADD-ON for Home Assistant
It is in maintenance mode and may not start after upgrades but does show total production figures every 15 minutes. I do not see each panel data and that undocumented way might stop to work at any fling from hoymiles.
For no network or quicker update times people are suggesting opendtu. It would not run in parallel so would need pairing of all inverters to that box.
@Maeckes have a look here:
