I want to share integration of Hoymiles - S-miles cloud with Home Assistant. To be honest this is not fully my project, but during last days I rewrite it to reach also own needs. In my case I have DTU-Pro which is not accessible so to get data I have to use unofficial API. I asked Hoymiles if they could share some doc but it is paid and not for customers. Here are some print screens:
In the Addon documentation it says that it can run without using Home Assistant, could you help me how to do this? I would like to run only in Node-red and get the information with the MQTT Node
Hi, is it possible to integrate the smart meterâs data (ddsu666) into the addon? My project is to switch on the air conditioner only if there is energy surplus generated by the solar panels.
This is nice addon, but seems like it stops working every now and then. I notice it when I look at my energy panel in Home Assistant and there is no solar production anymore (even when I have sold extra power to grid). When I stop the addon and then start it again, the next time full hour comes (and energy panel updates), I get a huge spike (all produced solar data since the addon stopped working, up until that point when I got it working again). Earlier it was crasing a couple of times per month, now it crashed yesterday and now today again.
I am basic user and I would like to use the Add-on.
The message is 502 bad gateway. is it a error by my side or s-miles change something.
Thanks in advantage.
Do you have the installer credentials? I am looking to âswitch offâ the microinverters automatically. Which is possible once you log in with installers account in the s-miles cloud. But just checking whether you looked into that part?
I have a dynamic energy contract, so once itâs too much negative, it would be beneficial to switch off the solar panels. This is actually the only thing I am missing in this add-on. For the rest al creds to good work! Love the add-on!
for some days im receiving the following error and the sensors are stopping and not be available.
maybe someone is facing same issues and could help out.
Entity sensor.hoymiles_gateway_solarh_3521870_real_power_measurement (<class âhomeassistant.components.mqtt.sensor.MqttSensorâ>) is using state class âmeasurementâ which is impossible considering device class (âenergyâ) it is using; expected None or one of âtotalâ, âtotal_increasingâ; Please update your configuration if your entity is manually configured, otherwise create a bug report at Issues ¡ home-assistant/core ¡ GitHub
hi,
big noob here
im havin problems getting it up and running⌠as i open it in the HA add-ons page, configure it start it and as i look into the log files it says-
alueError: invalid literal for int() with base 10: âKesk tee 3â
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Can you help me or im too far gone with this one and its easier to just quit ?
EDGE goes to full development mode - will be rewritten from scratch
Addon is in maintenance mode. This is FOSS (Free Open Source Software) and based on reverse engineering so it could not work always as expected. What is more due to techical dept present implementation loose possibility to add new features. This mean that it required rewriting from scratch. Without support from community it is not predicted soon.
Br, Cosik.
For me this doesnât seem to work since the second of mayâŚ
Is it correct that this addon will not work anymore?
