HP T620 Quad Core 4 Gb RAM 16 Gb SSD
I am new here and want to run home assistant on a HP T620 with 4 Gb ram which I have bought for this purpose.
The SSD is 16 Gb. Will this be enough or can I beter find a bigger disk.
I woould like to know this before I have setup everything to find out the disk is full :stuck_out_tongue:
Thank you very much in advance.
Kind regards!
The, documented, minimum is 32 GB - and people rarely say I have too much disk space.
Oke thanks good to know!
I wouldn’t recommend going under the 32gb recommended, but just so you know, my current HAOS install is using under 10gb of disk space, with 1gb of that being backups.
And what comes to T620, im using T610, works fine.
