Im getting errors compiling the HP303b code:
hp303.yaml: In lambda function:
hp303.yaml:52:28: error: expected type-specifier before ‘HP303BSensor’
hp303.yaml:54:24: error: could not convert ‘{hp_sensor}’ from ‘’ to 'std::vector<esphome::sensor::Sensor
i2c:
sda: D2
scl: D1
scan: True
- platform: custom
lambda: |-
auto hp_sensor = new HP303BSensor();
App.register_component(hp_sensor);
return {hp_sensor};
sensors:
name: "HP Barometric Pressure"
icon: "mdi:gauge"
unit_of_measurement: hPa
accuracy_decimals: 1
any ideas why?
thanks
jim
nickrout
(Nick Rout)
February 19, 2022, 2:58am
2
where does this code come from?
nickrout
(Nick Rout)
February 19, 2022, 4:05am
4
Have you got the relevant libraries and .h file installed?
EDIT I think the libraries should be downloaded by esphome, but you do need the .h file.
Yes I do have them as library functions. I don’t know where to put them for use by the include
nickrout
(Nick Rout)
February 19, 2022, 5:16am
6
As I say the libraries should be handled by esphome. The .h file should be in the /config/esphome directory.
thank you so much - it works now. I put the hpe303b.h file in the esphome directory and it compiles now.
platform: $platform
board: $board
comment: "${comment}"
libraries:
- "Wire"
# - "esphome=https://github.com/dmptrluke/esphome_hp303b.git"
- "SPI" # lib from platformio
- "epshome=https://github.com/wemos/LOLIN_HP303B_Library.git"
includes:
- hp303b.h
the last time i tried this i did now have the - “Wire” library at the top and iirc i was generating the same error.
the Solution was:
put the line - “Wire” at the top of the libraries section
put the hp303b.h file in the esphome directory
jim
JudgeTread
(Judge Tread)
February 23, 2023, 8:17pm
9
Im trying to get this sensor working - and can’t work out where this set of code is supposed to go?
platform: $platform
board: $board
libraries:
- "Wire"
includes:
- hp303b.h
nickrout
(Nick Rout)
February 23, 2023, 11:37pm
10
In the yaml file in esphome.
JudgeTread
(Judge Tread)
February 24, 2023, 9:19pm
11
Thanks for the response.
I’ve got the following in the yaml for the esphome board, (the 2 other sensors with esphome support working fine.)
friendly_name: Garden Sensors
esp8266:
board: esp01_1m
libraries:
- "Wire"
includes:
- hp303b.h
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "#######################"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Dadc78"
password: "################"
i2c:
sda: 4
scl: 5
scan: true
captive_portal:
- platform: sgp30
eco2:
tvoc:
store_baseline: yes
address: 0x58
update_interval: 1s
- platform: sht3xd
temperature:
name: "Garden Temperature"
humidity:
name: "Garden Humidity"
address: 0x45
update_interval: 30s
- platform: custom
lambda: |-
return {hp_sensor};
sensors:
icon: "mdi:gauge"
I’m getting the following error when I try and compile it:
libraries: [source /config/esphome/esphome-web-dadc78.yaml:9]
Component not found: libraries.
- Wire
- esphome=https://github.com/dmptrluke/esphome_hp303b.git
- SPI
- epshome=https://github.com/wemos/LOLIN_HP303B_Library.git
includes: [source /config/esphome/esphome-web-dadc78.yaml:14]
Component not found: includes.
- hp303b.h
I have placed the hp303.h file in the “/config/esphome” file, which I assume is where is referred to above.
