I added a new HomeSeer Door/Window sensor today (HS-DS100+). It showed up as expected as a device, seems to be recognized correctly by ZWave JS
HS-DS100+
by HomeSeer Technologies
Firmware: 2.3
It’s created a few different entities. There seems to be some overlap, and I’m not clear on how these are distinguished.
We have binary_sensor.patio_door_access_control_window_door_is_open
which shows up with a door icon, but never changes from closed state.
Then there is binary_sensor.patio_door_door_window
which is a simple on off but does actually work as expected when the sensor opens or closes.
Another pair is binary_sensor.patio_door_home_security_tampering_product_cover_removed
and binary_sensor.patio_door_tamper
for the rear tamper sensor. In this case, they both work as expected, but again one is a simple on-off and the other shows safe or unsafe and a special icon.
So the question is: why two pairs of duplicate sensors, and what controls the icons or type of the binary_sensor? I believe I can force a new door sensor using a template sensor looking at the working one, but is there any reason why the first binary_sensor.patio_door_access_control_window_door_is_open
sensor doesn’t seem to work?
Looking within the ZWave JS to MQTT panel, I can see the two binary sensors and two notification sensors. I presume this is what becomes the four sensors I described above. But here in the ZWave panel, I can see all four are working as expected. So something is getting lost between ZWave JS and Home Assistant, or in the way the Home Assistant sensor is setup?
