Does anyone have an HS-FLS100+ (not the g2 version) and can modify the configuration parameters? I have one that seems to be working correctly as far as operation and reporting, but i cannot set the configuration parameters on it. wanted to check if anyone else is having that issue or maybe it is just my particular device.
I have a couple of those, they are difficult to work with. But once working have been very reliable.
They act as battery powered devices even if they are in USB power. So they need to be woken up on order to get their config parameters. And manually waking them up does not seem to always work. Best approach may be to set its wake-up interval to 60 minutes, come back in a day, and then it should process config changes within 60 minutes.
I will give that a shot, though they don’t look like they are sleeping in the UI and they are sending illuminance reports on a frequent basis. Do you recall what you did to set the wake up interval?
Are you both talking about the same device?
The HS-FLS100+ floodlight is a mains-powered device that doesn’t support Wake Up, so you can’t set any wake up intervals.
There is also the HS-FS100+ “Flex sensor” which is battery-powered (supports Wake Up) and can optionally be powered by USB.
FLS vs FS.
Thanks for clarifying that, I am talking about the mains powered floodlight, HS-FLS100+, also the original version of it, not to be confused with the HS-FLS100-G2.
I was confused and taking about the wrong device. Apologies.
no worries, i appreciate you trying to help me out
