Hi everyone, totally new to haas and hoping for some guidance including some examples. High level question, is it possible to have what I call kitchen light routine in one automation rule? This routine currently runs in google home, i’d like to toss it and use HAAS exclusively
- I have a hs220 (kasa dimmer switch). It is configured as a a light so i can leverage the dimming features. Via UI, the HS220 shows up as light, i can turn on, off and dim as required.
Here’s the routine i have setup in google home which i’d like to mimc in haas as one rule if possible
Monday - Friday
7am kitchen light comes on with 25% brightness
8am kitchen light increases to 50% brightness
9am kitchen light increases to 75% brightness
9pm kitchen light dresses to 50% brightness
9:30pm kitchen light decreases to 25% brightness
10pm kitchen lights are turned off
Saturday / Sunday:
bonus if this automation can also handle states check, for example if the light is increasing or lowering brightness so it doesn’t turn the light on or off. Further; i noticed while setting up a another rule, the sun feature; would be neat to replace specific times and instead use the offset of sun to maybe do the timings.
