I just finished this today. My first plugin for Home Assistant
Anyone interested in it?
Supports
sun
weather.home
weather.dark_sky
And the repo:
Supports
sun
weather.home
weather.dark_sky
And the repo:
Oh yes fine job !
thank you. i`ll finish tidying up things over here and post it to git with readme and everything
maybe i`ll find a good ui guru to help me with it
WOW !!! post it on git⦠hurry!! haha
// Keep up the good work!
Ohh I am here for this.
Well ⦠as promised
Here it is:
Shout out if anything
WOW !!! Nice
svrOffset how do I add this? I need 2 hours earlier
Dutch language:
regional['nl'] = {
monthNames: ['Jan', 'Feb', 'Mar', 'Apr', 'Mei', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dec'],
dayNames: ['Zon', 'Maa', 'Din', 'Woe', 'Don', 'Vrij', 'Zat'],
lang: 'nl'
Maybe you can implement also (left Bottom corner) the date of today. Then you have everything in 1 viewā¦
And maybe the left part next to image cloud, sun etc⦠you see min max temp. That change to temp at this moment and where the temp now is places the min/max, or you can add a custom entity to show for example inside temperature.
hey, thank you for the language. is there a place that you would find the date suitable? i`m finding it hard to image right now.
no sure what you mean
my bad⦠small bug there. i fixed it. i`ll push it to git after i do the date and what you requested
On left you see 22/19 thats the min max temp. Change to the current temp 22.1
On right you can have the min/max temp⦠or a custom entity. For the temp inside then.
ah⦠damn⦠iām stupid :)) got what you mean. i`ll see how i can do that and try to add it
good idea.
what about the date? where do you see it added?
Thatās seems nice and more logic. Would be nice that the min/max can be changed with a custom value.
If you can custom a different entity_id then people can place something else.
I will add my climate.temp so I have left temp oudside and right temp inside.
Iāll have a look at it tomorrow. I have an idea how to do that.
morning,
iāve added a custom entity_id to replace high / low temperature and added nl in regional support. download the latest version and update
yaml for this is:
- type: 'custom:htc-weather-card'
entity: weather.dark_sky
sun: sun.sun
high_low_entity:
entity_id: sensor.time_utc
Tried to clone the new files but still have the same layout and new options not work.
I only see the readme.md is updated.
get this:
forgot to push to masterā¦pushed only the tag
Great !!! On little thing I think then this card is done.
The text ābuienraderā and ātemp Insideā are different sizes. Even the values ā18.9Cā and ā24.0ā
If the text size are the same then its perfect !!!
Maybe the ātemp Insideā and his value same text sizeā¦
svrOffset seems not working
svrOffset: -120 (for min 2 hours)
