I think you should be able to access from
https://yoursite.com
NOT
https://you site.com:8123
I can’t. It does not work. I must specify the port and other people find this as well.
I’m still having trouble getting my UI to open with HTTPS. I have the certificate issue still… Are you able to help please @DavidFW1960 ? My config is as per below which I thought should work…but doesnt.
config.yaml
http:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: https://myaddress.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
DuckDNS Add-on setup
router config:
and yet STILL…
Which is both annoying in its own right, but apparently stopping me from getting the HTML5 notifications setup
actually… I think I found my problem. I was logging in at home using my RPi IP address which obviously doesnt have the associated certificate. I just tried using my DuckDNS address from home and it says its secure with HTTPS tried on my phone as well and its happy too.
Now to get the notifications going!
@sparkydave hahaha! well done. Yeah I get the not secure if I don’t use the duckdns address. Didn’t occur to me you were not doing that.
unfortunately my work blocks DuckDNS so I have to use my routers external IP to bypass the block. When at home I was just using my local IP as its faster to load everything. Now that I fixed the port 80 forwarding in my router I can get a secure connection on my phone via DuckDNS and the HTML5 notifications work. very happy.
Now if I can only get owntracks to work as well…
