HTML5 Push Notification error: Saving config file failed
I’m running HASS 0.30.2 on Win 10.
I’ve managed to receive notifications on the first android phone but when I try to get notifications on the second one, I never receive them on the second phone.
I tried to unregister/register the second phone.
In this case, file html5_push_registrations.conf becomes empty and I get this error in log:
16-10-15 23:13:50 homeassistant.components.notify.html5: Saving config file failed: b'BKFXXXXXXXXXXXXX_XX-c=' is not JSON serializable
And I continue to receive push notifications on the first phone.
I’ve tried this:
  1. Shutdown Home Assistant
  2. pip uninstall pywebpush
  3. pip install “https://github.com/web-push-libs/pywebpush/archive/e743dc92558fc62178d255c0018920d74fa778ed.zip#pywebpush==0.5.0
  4. Start up Home Assistant
  5. Attempt to send a notification over HTML5
But it doesn’t help.
I’d like to add that there were several same issues #3154, #3028 and #3382. All of them are closed as fixed.
However, someone mentioned that the issue might be due to registration/unregistration problem or due to that one identifier contains a single quote < ’ >.
Could someone look at this issue again since it seems not solved?
https://github.com/home-assistant/home-assistant/issues/4012
The issue has partly been solved, however, the notifications still do not work for “problematic” clients. Some update for those who might be interested:
