Html5 push notifications with image
Yes yes is anabled and in the browser I see the image.
This work for me
  "data": {
    "image": "https://domain.com/api/camera_proxy/camera.south_gate",
    "renotify": 1,
    "tag": "alert",
    "timestamp": "%m",
    "url": "https://domain.com/states/group.camera",
    "vibrate": "700, 700, 700"
  "message": "{{ as_timestamp(now()) | timestamp_custom('%H:%M', true) }}",
  "title": "Pool Motion"
Yes, this works also for me… But how can I add a action button??
Like this
  - data:
        actions:
        - action: Open_Entry_Gate
          title: Open Gate
        - action: Dismiss
          title: Dismiss
Sorry about the poor formatting but this came from autoconfig file created by automation UI in HA and I do not want to muck around with spacing and provide something that hasnt been verified functional
To make button you need (x2) automation.
AUTOMATION 1
generates the notification and includes the buttons
AUTOMATION 2
receives the button response from HTML5 message and does the action you set
---------Below are code examples of each-------------
AUTOMATION 1 EXAMPLE
When Ring Doorbell Motion is sensed, a message is sent that has buttons [Open Gate] and [Dismiss] with some text and an image
action>>data>>data>>actions>>action defines the button
- id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  alias: NOTIFY_GateMotion
  - entity_id: binary_sensor.ring_entry_gate_ding
    platform: state
    to: 'on'
  - entity_id: binary_sensor.ring_entry_gate_motion
    platform: state
    to: 'on'
  - data:
        actions:
          title: Open Gate
        - action: Dismiss
          title: Dismiss
        image: https://mysite.com/api/camera_proxy/camera.front_door
        renotify: 1
        tag: alert
        timestamp: '%m'
        url: https://mysite.com/states/group.garage
        vibrate: 700, 700, 700
      message: '{{ as_timestamp(now()) | timestamp_custom(''%H:%M'', true) }}'
      title: Entry Gate Motion
    service: notify.notify
AUTOMATION 2 EXAMPLE
When “Open Gate” pressed in Automation 1 notification, HA receive some listener reply and perform an action. It knows the action to perform based on the “action” specified in both automations. In this case the action will Turn ON entry gate (open gate)
trigger>>event_data>>action identifies the listener and should match action for automation 1 button
  alias: NOTIFY_Html5NotificationClicked
  - event_data:
    event_type: html5_notification.clicked
    platform: event
  - entity_id: switch.entry_gate
    service: switch.turn_on
How do I feed the user credentials to access API, so that I can get camera images?
My image was cropped like @deviant experienced way back in 2018.
I fixed this now by giving the notification the url under data to be send to the entity_picture when you click the notification.
When someone rings my doorbell I have an automation with the following action:
Sending html5 notification with: message, picture of cam1 (cropped), 2 buttons to open the door and when you click the notification it opens the full image.
   - service: notify.html5notify
       message: "Ding Dong, deurbel ingedrukt"
            actions:
              - action: open_door_5s
                title: Deur open 5s
              - action: open_door_10s
                title: Deur open 10s
            image: https://yourthing.duckdns.org/api/camera_proxy/camera.cam1?token=[use your own access token here]
            url: https://yourthing.duckdns.org/api/camera_proxy/camera.cam1?token=[use your own access token here]
