Anyone know how to control a windows pc using homeassistant… Basically to emulate a keyboard? Been playing around with the new Plex HTPC install and want to see if I can control the pc Plex UI using homeassistant. You can customize the Plex Input Map… Plex HTPC Input Maps | Plex Support
If it were me, I would use Eventghost to control Plex (only because I have used EG in the past for that and there’s a lot you can do with it). There is an MQTT plugin for EG so that could be used. The benefit from controlling EG from Home Assistant is that you could control other stuff with it as well.
