HTTP 500 Errors with camera
Hi
I have a problem with adding a camera. For simplicity my dashboards configs are in the same directory as the HA configs
2017-09-16_14-19-01
Dashboard Structure
I have tried adding a camera but whenever attempting to display the dashboard I get a 500 error.
I can’t seem to find a log file for appdaemon anywhere, I have tried running it in foreground with the -D DEBUG option but no error is displayed.
The code for the dashboard is as follows
## Main arguments, all optional
title: Lounge
widget_dimensions: [120, 120]
widget_margins: [5, 5]
columns: 9
lights_label:
    widget_type: label
    text: Lights
switches_label:
    widget_type: label
    text: Switches
environment_label:
    widget_type: label
    text: Conditions
security_label:
    widget_type: label
    text: Security
lounge_temp:
    widget_type: gauge
    title: Temp
    min: 0
    max: 50
    units: "°C"
    entity: sensor.netatmo_indoor_temperature
lounge_humidity:
    widget_type: gauge
    title: Humidity
    min: 0
    max: 100
    units: "%"
    entity: sensor.netatmo_indoor_humidity
lounge_noise:
    widget_type: gauge
    title: Noise
    min: 0
    max: 100
    units: "dB"
    entity: sensor.netatmo_indoor_noise
lounge_co2:
    widget_type: gauge
    title: Co2
    min: 0
    max: 2000
    units: "ppm"
    entity: sensor.netatmo_indoor_co2
living_room:
    widget_type: camera
    title: Living Room
    #refresh: 1
    entity_picture: !secret lounge_cam_url
layout:
  - include: header
  - lights_label(2x1), light.lounge
  - switches_label(2x1), switch.alex, switch.becs
  - environment_label(2x1), lounge_temp, lounge_humidity, lounge_co2, lounge_noise
  - security_label(2x1), sensor.lounge_motion, sensor.back_door
The relevant section of the secrets file, url, password and token have been redacted. The url is the external domain for the HA installation not a local IP.
Doing a local curl of the url does provide a still image as expected so the url is okand the camera is working fine in HA.
I have not added the camera to the dashboard, the error is thrown with just the definition.
# Cameras
lounge_cam_url: https://<redacted>/api/camera_proxy/camera.lounge?token=<redacted>&api_password=<redacted>
Anyone have any ideas?
Alex
i would try it without the token, but i suspect that the problem is httpS
you probably have setup encryption for HA which can be a problem.
if your setup is correct and if HA and AD are on the same device there should not be a problem to reach HA without encryption like:
http://ip:8123/api/camera_proxy/camera.lounge?api_password=
if you get a picture when you try that in a browser then i should use that.
and to be sure just first add it in your dash and not in secret.
Thanks for the quick reply.
I have tried that but still get the same 500 error. I have …
  1. Removed all SSL from HA and Appdaemon
  2. Tried the IP camera url in a browser (works fine). This was without the token
  3. Add it to the dash in the dash file
Still getting a 500 error :frowning:
Cheers
Alex
did you clear cache in between trying?
did you clear the compiled dir in between trying?
did you try just this:
title: Lounge
columns: 9
living_roomcam:
    widget_type: camera
    title: Living Room
    entity_picture: http://<redacted>/api/camera_proxy/camera.lounge?api_password=<redacted>
layout:
  - living_roomcam
Hi
Again thanks for the reply
I didn’t clear the cache but did force a recompile from the browser. I did try just adding the url to the dash rather than using secrets.
Alex
make sure you deleted the compiled files after an errorpage, to be sure that it is recompiled.
from the browser you cant force that.
and try to make a new dashboard like i showed, to make sure its working.
Perfect thanks.
Clearing the compiled directories has removed the 500 error but only if the camera url is in the dash file. If I put the camera url in the secrets file its not working but I will dig into that a bit more
Cheers
Alex
you could try to make it quoted with single or double quote (remember to clear before you retry)
its probably a YAML error that triggers the 500 error page.
I tried using double quotes and clearing the cache but still no luck, not getting the 500 error just no image
I’ll start digging through the code as I suspect it cannot find the secret, the src attribute in the iFrame is null which leads me to think it cannot find the value
Cheers
Alex
