Http API usage
Hi folks,
I’m just beginning to use the RESTful API and have managed to get responses from the (MacOS) command line to the following command:
curl -X GET -H "Authorization: Bearer <API_key>" http://homeassistant.local:8123/api/states/sensor.sr_ms_frontporch_temperature
Is there any way to issue a cURL command like this from a web browser via a URL? I’ve migrated from Homeseer and used to query one of my sensors from an ESP32 with the following URL (getting a JSON return).
http://<ip_address>:42400/JSON?request=getstatus&ref=615
where 615 was the device ID.
Grateful for any help.
Aljrob
