For now, am not going through https, but just http. Was trying with the new .87 release to set up things for my Smartthings and following the directions, once I have my api key, I simply just config for this, but like others, then submit isn’t work and so I thought maybe it is the way I was setting my base_url or my http within my configuration.yaml.
For just simple http, is it not just?:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: http://xxx.xxx.x.x:8123
