HTTP Binary Sensor using IFTTT
I am trying to create a binary sensor for a door using IFTTT trigger and webhook. But it is not working as I am trying to piece together a bunch of reading.
I originally started here: Sensor for IFTTT
The api password…is that the legacy password? https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
Here are the configurations I did so far.
In configuration.yaml
homeassistant:
  auth_providers:
   - type: legacy_api_password
     api_password: !secret http_password
Then ins secrets.yaml
http_password: MYPASSWORD
In IFTTT
URL: https://domain:8123/api/states/binary_sensor.skylink_basement_sensor?api_password=MYPASSWORD
METHOD: POST
Content type: application/json
BODY: {"state":"on", "attributes": {"friendly_name": "Skylink Basement Sensor", "icon":"mdi:human-male"} }
After this when the sensor triggers, I get the notification in Hassio, Login attempt or request with invalid authentication from IP ADDRESS
What am I doing wrong here?
Also I am reading that the new method for HTTP is to use the long lived token. I have created the token, but how do I use it in the URL? What are the additional config I have to do?
Sorry, for some I know this is obvious. I am still learning and hope you guys will be patient. And I truly appreciate the help.
Ok…looks like my approach to this was all wrong. The better approach is to create and Input Boolean.
In the configuration.yaml I created the following:
input_boolean:
  skylink_basement_sensor:
    initial: off
    icon: mdi:car
and in IFTTT I used the webhook method (the IFTTT integration): https://www.home-assistant.io/integrations/ifttt/
https://domain.duckdns.org:8123//IFTTKEY
URL: https://domain:8123/api/webhook/IFTTTKEY
METHOD: POST
Body:
{ "action": "call_service", "service": "input_boolean.turn_on", "entity_id": "input_boolean.skylink_basement_sensor" }
I am going to now look into how to customize the sensor further.
Hey War, would that url work does it not need to include webhook, in example :
https://yourdomain.duckdns.org:8123/YourApiKey
ps to get mine to actually work I had to remove the port from the url
