2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.loader] Unable to find component auth_providers
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/home/homeassistant/dehydrated/cert$
not a file for dictionary value @ data['http']['ssl_key']. Got '/home/homeassistant/dehydrated/certs/tientjesstraat.duckdns.org/privkey.pem'. (See /home/homeassistant/.homeassistant/configuration.$
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: auth, http
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, websocket_api, http, system_log, auth, onboarding
2019-04-07 11:22:17 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.loader] Unable to find component auth_providers
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for auth_providers: Component not found.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: api
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of conversation. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of google_assistant. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for google_assistant: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_player. Setup failed for dependencies: http
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, config, conversation, frontend, history, logbook$
2019-04-07 11:22:18 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
does it matter where âhttp:â is placed inside configuration.yaml?
ok, found alot of errors in my configuration.yaml indeed
still get following error now :
2019-04-07 19:41:50 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: file not readable for dictionary value @ data['http']['ssl_certificate']. Got '/home/steven/dehydrated/certs/xxxxxxxx.duckdns.org/fullchain.p$
file not readable for dictionary value @ data[âhttpâ][âssl_keyâ]. Got â/home/steven/dehydrated/certs/xxxxxxxx.duckdns.org/privkey.pemâ. (See /home/homeassistant/.homeassistant/configuration.yaml, line 38). Please check the docs at$
2019-04-07 19:41:50 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2019-04-07 19:41:50 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http
2019-04-07 19:41:50 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: auth, http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, websocket_api, http, system_log, auth, onboarding
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of google_assistant. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for google_assistant: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: api
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of conversation. Setup failed for dependencies: http
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: Could not set up all dependencies.
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2019-04-07 19:41:51 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_player. Setup failed for dependencies: http
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: Could not set up all dependencies.
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, config, conversation, frontend, history, logbook, mobile_app, system_health, zeroconf
2019-04-07 19:41:52 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
the files are definitely there because if I run the following command its shows me the file
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 50.85
longitude: 3.3
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Brussels
# Customization file
customize: !include customize.yaml
# authentication providers
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- 192.168.0.0/24
- type: legacy_api_password
api_password: myAPIpassword
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
# introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate: /home/steven/dehydrated/certs/xxxxxxxx.duckdns.org/fullchain.pem
ssl_key: /home/steven/dehydrated/certs/xxxxxxxx.duckdns.org/privkey.pem
base_url: xxxxxxxx.duckdns.org:8123
# Discover some devices automatically
discovery:
