http://192.168.0.191/sendCommand?data=[254, 171, 127]
is there anyway to change the value in the [ xxx, xxx , xxx ] to [msg.payload.col1,msg.payload.col2,msg.payload.col3] ?
Try using a change node, setting msg.payload to J: expression (JSONata)
with
"data=" & [payload.col1, payload.col2, payload.col3]
where I assume you are using msg.payload as ‘append to query string parameters’
JSONata, when using the & string concatenator, will stringify an array directly, hence ‘payload.col1’ is all that is required to lift the values.
thats awesome thank you! will help with dimming from ui
