Hope everyone is well.
I am trying to update Weather Underground using an HTTP GET request via Node Red, with sensor data contain in the HTTP address:
http:/weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=XXXX&PASSWORD=XXXX&dateutc=now&winddir=XXX&windspeedmph=XXX&airpressure=XXX&tempc=XXX&humidity=XXX&dewptc=XXX&action=updateraw
The various sensors are as follows:
Wind Speed
Air Pressure
Temperature
Humidity
Dew Point
This data is displayed in Home Assistant, as sensor entities from Node Red. The setup is as per the below:
[{"id":"720ab126.608a6","type":"tab","label":"Weather Meter","disabled":false,"info":""},{"id":"6bff04c3.1d096c","type":"csv","z":"720ab126.608a6","name":"","sep":",","hdrin":false,"hdrout":"none","multi":"one","ret":"\\n","temp":"NODE,DIR,SPEED,PRESS,TEMP,RH,DEWPOINT,VOLT","skip":"0","strings":false,"include_empty_strings":false,"include_null_values":false,"x":210,"y":300,"wires":[["68100633.dfa9c8"]]},{"id":"68100633.dfa9c8","type":"split","z":"720ab126.608a6","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":340,"y":300,"wires":[["d9c14757.617bd8"]]},{"id":"d9c14757.617bd8","type":"switch","z":"720ab126.608a6","name":"","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"NODE","vt":"str"},{"t":"eq","v":"DIR","vt":"str"},{"t":"eq","v":"SPEED","vt":"str"},{"t":"eq","v":"PRESS","vt":"str"},{"t":"eq","v":"TEMP","vt":"str"},{"t":"eq","v":"RH","vt":"str"},{"t":"eq","v":"DEWPOINT","vt":"str"},{"t":"eq","v":"VOLT","vt":"str"}],"checkall":"true","repair":false,"outputs":8,"x":490,"y":300,"wires":[[],["4d7c233a.fb1b5c"],["3c4d1d1c.1621f2"],["36e6b8ce.bbd9b8"],["a1d3ffc.48e15"],["c073d016.b79fe"],["61b63dad.b9e4b4"],["eb0f2b22.eb6668"]]},{"id":"4c2d8b30.068334","type":"udp in","z":"720ab126.608a6","name":"","iface":"","port":"2559","ipv":"udp4","multicast":"false","group":"","datatype":"utf8","x":60,"y":300,"wires":[["6bff04c3.1d096c"]]},{"id":"27d9d361.a0263c","type":"ha-entity","z":"720ab126.608a6","name":"External Wind Speed","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external wind speed"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"Mph"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":920,"y":240,"wires":[[]]},{"id":"51b22e6d.0ae55","type":"ha-entity","z":"720ab126.608a6","name":"External Air Pressure","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external air pressure"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"mbar"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":920,"y":280,"wires":[[]]},{"id":"7b7526c1.4a9d68","type":"ha-entity","z":"720ab126.608a6","name":"External Temperature","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external temperature"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":920,"y":320,"wires":[[]]},{"id":"5364900b.3b29e","type":"ha-entity","z":"720ab126.608a6","name":"External Humidity","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external humidity"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"%"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":910,"y":360,"wires":[[]]},{"id":"25b0ae57.beb3d2","type":"ha-entity","z":"720ab126.608a6","name":"External Dew Point","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external dew point"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":910,"y":400,"wires":[[]]},{"id":"68bf2d8c.1ea8d4","type":"ha-entity","z":"720ab126.608a6","name":"External Station Voltage","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external station voltage"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"Vdc"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":930,"y":440,"wires":[[]]},{"id":"4d7c233a.fb1b5c","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":200,"wires":[["c1523db1.25f98"]]},{"id":"3c4d1d1c.1621f2","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"4","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":240,"wires":[["27d9d361.a0263c"]]},{"id":"36e6b8ce.bbd9b8","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":280,"wires":[["51b22e6d.0ae55"]]},{"id":"a1d3ffc.48e15","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":320,"wires":[["7b7526c1.4a9d68"]]},{"id":"c073d016.b79fe","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":360,"wires":[["5364900b.3b29e"]]},{"id":"eb0f2b22.eb6668","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":440,"wires":[["68bf2d8c.1ea8d4"]]},{"id":"61b63dad.b9e4b4","type":"delay","z":"720ab126.608a6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":720,"y":400,"wires":[["25b0ae57.beb3d2"]]},{"id":"c1523db1.25f98","type":"ha-entity","z":"720ab126.608a6","name":"External Wind Direction","server":"eabe397b.2e7ab8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"external wind direction"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":930,"y":200,"wires":[[]]},{"id":"eabe397b.2e7ab8","type":"server","name":"Home Assistant","addon":true}]
What i need to do is take the various values, and add these to the HTTP address - as an example, the switch output for “temperature” updates the “tempc=XXX” part. The data would need to update every 60 seconds.
Any ideas? This is the first time i have done something like this.
Thanks.
