I’m trying to reach a HTTP in node from an external IP address, but the connection always times out.
My setup:
My Home Assistance Supervisor is installed in an virtual environment on a QNAP NAS. The instance is reachable from outside my network through a secured duckdns domain. Internally I use my local IP address. This is accomplished with a reverse proxy (NGINX). I have no problems with that.
The node red dashboard is reachable with my duckdns domain without any problems.
The HTTP in node is reachable with my local IP address. The only thing that doesn’t work is to reach the HTTP in node with my duckdns domain. No matter what combination I try, it doesn’t work. I think it has something to with ports, but I can’t figure out the solution.
I have tried these addresses:
- http[s]://myinstance.duckdns.org:1880/endpoint/test
- http[s]://myinstance.duckdns.org:8123/endpoint/test
- http[s]://myinstance.duckdns.org:8123/a0d7b954_nodered/endpoint/test
I would appreciate any input.
