I have been using a http node to get a web request into a flow and was working wonderfully. I was using Hassio vers .89 something. I upgraded Hassio and Node red etc to the latest and had to ask how to get to the old web interface.
However I now cant get the http in node to work. Trying it from a browser it asks the login name and password and I used the same one I have been using for weeks and checked it was in the config file but it keeps getting rejected.
I am out of ideas?
[20/Apr/2019:20:47:04 +1000] 401 -(192.168.1.248) GET /hello2?camera=front1 HTTP/1.1 (Wget/1.17.1 (linux-gnu))
[20/Apr/2019:20:47:05 +1000] 401 -(192.168.1.248) GET /hello2?camera=front1 HTTP/1.1 (Wget/1.17.1 (linux-gnu))
[20/Apr/2019:20:47:09 +1000] 401 -(192.168.1.56) GET /hello2?camera=frontstair HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36)
19-04-22 07:17:42 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for httpnode
19-04-22 07:17:43 WARNING (MainThread) [hassio.auth] Wrong login from httpnode
Yes it was working for me as well. It just stopped after I upgraded. However I may have had a sd card failure and have rebuilt the whole thing. Just spent the day installing stuff again so will see the next day or so.
I use it to get movement input from my Xoema cameras and then it marks the cctv foorgae with text so I can see what was going on when reveiwing the foorgae
Using the name and password as in the config and the http port but refusing
19-04-24 05:19:02 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for httpnode
19-04-24 05:19:04 WARNING (MainThread) [hassio.auth] Wrong login from httpnode
Try clearing your local storage auth credentials. There was an issue like this for 3.0 of the node red addon. In Chrome Ctrl-Shift-J, application tab, local storage on the left, delete the stuff.
Tried it from a completely different browser and same issue. Actually in an effort to get something I use it for going I thought about using a websocket node but it seems to have the same issue. Will keep working at it but its driving me crazy
Out of interest is there a way of turning off the authentication so that it will simply let any request? I dont have my system exposed and only need to get a web request from my cctv server into node-red so authentication isnt a high requirement for me
No I am using it the other way. My camera server has a http request into my node red. When it sees motion it sends a http request to the node-red. It normally passes the user and password in the http string but at the moment node-red is rejecting it. I used to use the httpnode username and password. Can I disable that part in node-red
Hey @Secs , wondering if you ever got this working? I’m trying my first httpIn for node-red addon, and I can’t even figure out what the base URL should be.
I had it working beautifully. But I was a few upgrades behind and I went from .89 or simalar to 9 something in HA and it broke. For whatever reason it will not authenticate no matter what I use for username/password. I even did a fresh install of HA and get the same result so havent worked it out. Even using wget calling it from Linux command line gets a failure so not sure.
I come back and play every so often but have other bits and pieces I have been doing.
I followed https://cookbook.nodered.org/http/create-an-http-endpoint originally to get it going. I used it to have my CCTV system to pass data back to node-red
I was using the port of the node-red interface. I am just in the middle of a job in the house for she who must be kept happy but when thats finished I will have a play again
Just tried it again. No luck either by using chrome in a web browser or linux via wget. Tried using the Hassio port or the one I have as an external to Node-red. Tried the httpnode username and password and also tried the username and password I log into Hassio with. It keeps getting an authentication failure
