I am trying to configure 0110.0 as a test environment.
I am using a docker install of core HA
After setting up a new config folder and setting up the docker naturally the (default) port is 8123.
I understood that I can use the HTTP integration to set the default port to another port (of my choice) however once I edit config.yaml to do that I can no longer connect to HA on either the 8123 port or my new choice of 8889.
Here is my edited config.yaml:
http:
server_port: 8889
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Anyone have a clue what I may be doing wrong or is what I’m attempting not possible?
Restarted the container that is?
EDIT: Small progress
Checked log again after adjusting config to:
config:
http:
server_port: 8889
# Text to speech
tts:
Log:
2020-05-20 10:45:31 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8889: [Errno 98] error while attempting to bind on address (‘0.0.0.0’, 8889): address in use
So rejigged the config to:
config:
http:
server_port: 8870
# Text to speech
tts:
This is a very old topic, but I want to ask too (especially that it’s solved), what changes will the users feel if integrating HTTP in your smart home, other than the changed port here (to 8125)?
