I’m having issues to use Home Assistant running on Docker and using Traefik as reverse proxy.
when I hit the URL defined on Traefik I get an 400: Bad Request error and looking the HASS log I see:
2022-01-09 11:19:59 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 172.18.0.4, but your HTTP integration is not set-up for reverse proxies
On the configuration.yaml for home assistant I’ve the following parameters for the HTTP:
