HTTP panel in HTTPS HA
Hi
I know there’s a limitation to add iframe/panel with http link if whole HA running using https.
Any chance it can be done?
I want to include the configurator and the HADashboard as panel in HA.
This isn’t a limitation in HA, it’s a limitation in the browsers. This page may help to explain what is going on:
I believe a new version of Configurator now allows you to use port forwarding to overcome this and has a user configurable login/password to prevent direct access to your HA configuration; I was working with the dev on this but haven’t had a chance to set it up and test. Port forwarding the 3128 port he’s using works, but without setting up the separate authentication, anyone who sniffed the port would have access; that’s why he added that feature.
