The task connects but it is turning on all the lights, not just light.kitchen. When fired from the services menu of HAss it works just fine. I’ve found a few similar threads but the ones with examples have used pictures that are now deleted and everything else I have found seems to suggest I’ve set it up correctly.
Thanks @ih8gates. I tried splitting it like that, mapping port 80 to 8123 and so on. All seem to connect and have the same result - every single light turns on. I might try changing from light/turn_on to homeassistant/turn_on but that will have to wait until I can deal with a million things all turning on at once.
What I’m actually trying to do is get around a presence tracking issues and set off a front door light when I get home in the dark, maybe I might borrow another one of your ideas and use an “enable first morning trigger” style input boolean to my presence activated lights.
I just installed tasker on a new phone yesterday so maybe I’m missing some other bits, I’ll try restoring my previous tasker stuff and plugins and try again.
I tried many variations of the entity line including that one, the one above I’m using was copied directly from home assistant.
Nmap half works but I don’t want my lights going off and on all night each time my phone checks out so the boolean limiting it to a once off will work. On my old phone this wasn’t a problem, I suspect Nougat is saving battery by disconnecting.
