I migrated my Nodered flows from a stand alone container to a “home assistant addon”
Everything seems to work except an http request to an https site.
I tried to find a solution but except from a long closed thread on nodered github I don’t find any solution to this.
In the http request on my standalone container “enable secure connection” was disabled.
So I tried enabling this but there isn’t much I can configure nor is there any explaination what should be configured.
This seems to be just a client certificate (which I don’t need) and some other filters which I don’t need either.
I can’t reach that link in a browser. I can tell you I am on a http haos install and have no problem retrieving results from https sites. Have you tried another https source to see if this is consistent or just this site?
If I search this error I get results, not NR, but all pretty much point at a proxy problem.
Well maybe it’s geoblocked but you should get a “forbidden” message.
To be complete, tried google.com, same error
And there is no proxy, and it works an a standalone nodered
Have you changed anything in the settings.js file for NR? You can also try deleting the http node, deploy, drag out a new one. Other than that, I don’t know of anything else to try.
No, I did compare it now with the standalone but I don’t see anything strange or related to this issue.
I also never changed the standalone nodered settings.js.
Experiencing similar issues here. Started happening after migrating to a new host (ubuntu 24.04) and updating nodered (to v3.1.9). Not sure which of the two actions could have caused it. Only http request work. Even for a website like google.com.
I think this is related to the way HAOS layers containers. According to the docs NR addon uses/ssh for cert location and that can’t be changed. For example, when using shell commands, you need to create new certs in the config folder for them to work.
How does this apply here, I’m not sure. What you can do is download wire shark and monitor your HA IP and make the request. IIRC bounced https requests will be highlighted in black. You will be able to see what was sent and what the response was, from that you should be able to see exactly what is going on.
Edit: I am assuming that the HA stores ssl certs in the same location/level as the ssh certs, which is not accessible when running commands.
How is this related to cert location?
Even if it was, than curl wouldn’t work as well, which it does.
And even if I see what happens in wireshark, I’m not going to be able to fix it.
So who do I talk to? or where?
