help, I performed the procedure to be able to connect to my Home Assistant with the https protocol using the duckdns.org site.
Remotely it works very well, from within the home network it does not work from android, from PC instead it works.
My router uses the hirpin on, if i disable it the pc no longer connects then the router works properly it seems. Only smartphones don’t connect from my home network with the address https://mydomain.duckdns.org:8123.
Can you help me?
