I am a bit frustrated in trying to setup ssl / https access to my homeassistant host.
According to the documentation, a suggestion is to use the " add-ons Duck DNS integrating Let’s Encrypt or Let’s Encrypt." But neither provide sufficient explanation for setup.
Actually, the link from the documentation provides a loop in stating: " If you are using Home Assistant do not use this guide. Instead, use the DuckDNS add-on "
I feel like I am pretty savvy when it comes to port forwarding ( I have several hosts behind my router with various ports exposed, including VPN), but I wanted to try out the “easier” ssl direct forward. However, I am confused as to how to address this misconfiguration - i.e. no logs or anything indicating what is wrong. I was able to access via https://myhostname.duckdns.org, but could not access locally from the app on my phone.
Has anyone found a step-by-step setup for this, and if so, could you please share it and add it to the documentation?
Thanks!!
