HTTPS for your HomeAssistant in your local LAN
Situation
Your HomeAssistant instance is connected to the internet, but not reachable from the internet. You want to have a certificate signed by a well-known certificate authority for your HomeAssistant to be able to connect by HTTPS to your HomeAssistant.
Solution on my HomeAssistant Green:
DuckDNS.org “dynamic” dns + Letsencrypt addon + nginx addon
Howto:
  1. create a DNS entry on duckdns pointing to your local HomeAssistant instance (for example xyz.duckdns.org with ip 192.168.1.133). Copy the token for later use.
  2. Install the Let’s Encrypt addon (Settings → Add-ons → Add-on store) and configure like this:
  1. Install the NGINX Home Assistant SSL proxy . Follow exactly the documentation regarding configuration settings in configuration.yaml. Restart everything. Check https://xyz.duckdns.org
  2. Configure a daily automation to start the Let’s Encrypt addon. This will ensure renewal of the certificate on time. I configured it with the GUI (Settings → Automations). This is the generated YAML:
alias: Letsencrypt
description: ""
  - platform: time
    at: "00:30:00"
condition: []
  - service: hassio.addon_start
    metadata: {}
      addon: core_letsencrypt
mode: single
  1. Configure the internal URL to HTTPS: Settings → System → Network → Local Network → Disable “Automatic”, Enter https://xyz.duckdns.org. Restart everything.
Hi I’m accessing my home assistant on internet using cloudflared add-on, but i can’t use https on local for microphone usage. Can i do the above steps to get local https with cloudflared enabled?
Do you have Always Use HTTPS enabled in your Cloudflare settings?
Can you describe what happens when using https: on local for microphone usage?
