Hi
I’m pretty new in Home assistant.
I looked for a week the right method to publish it on internet as it is reachable from outsive (via web browser or app)
I read dozens of docs getting a lot of information, but non oth it was ca complete step by step guide
Finally I found the right way, so I would like to publish it here to help future new Home Assistant installer
make a backup of your HA
be sure to be able to restore it from comand line interface in case of need -
install terminal & ssh add on
config password & tcp port
start add on
connect using the “root” user and the password set
check the folder /ssl dos not exist or it is empty
→ cd /ssl
→ ls -
configure nat/publish in you router
to let reachable HA from internet on port 80 (outside/inside)
as let’s encrypt add on enable a temporary webserver running on port 80 -
be sure that the hostname you want to use is resolved correctly by a public dns
hostname → you public ip address
(you need to own a public domain) -
install let’s encrypt add on
configure
domain → hostname
email → your email address
challenge → http
network → 80 (80/tcp)
save and start the addon
see the logs for any issue
if everythinis ok, cert and key will be saved on /ssl folder
to access the folder, connect via ssh (see point 1))
→ cd /ssl
→ ls -
disable the nat/publish on port 80 on your router
to let reachable HA from internet on port 8123 (outside/inside)
if you need to speicfy the protocol, select https -
edit your configuration.yaml
add the following
#SSL
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
on HA → settings → network → home assistant usr
internet → leave empty
local network → disable “automatic”
local network → set “https://you-url-public:8123” -
restart HA
you should now connect to HA by using the public url both from inside and outside
your router should take care about reachability of the HA from inside
