Does anyone have a working configuration of a htu21d sensor connected directly to a RPI3B+ with Hassio in 2022?
I have tried many solutions, the i2C bus is active but HASSIO gives me this error after editing configuration.yaml :
Errors :
Platform error sensor.htu21d - Integration 'htu21d' not found.
Integration error: i2c - Integration 'i2c' not found.
What I add in configuration.yaml :
i2c:
sda: GPIO2
scl: GPIO3
scan: true
- platform: htu21d
temperature:
humidity:
update_interval: 60s
The sensor works perfectly with ESPHome on an ESP32 with this configuration.
I used this repository to activate i2c: [add-on] HassOS I2C Configurator
I also checked the folders on the SD card directly, they were edited correctly by the add-on above.
Any ideas ? Thanks !
