I can´t figure it out how to get an Huawei Android Telephone to push an important alarm notification to get even through Android Do-Not-Disturb.
Everything i try only gets me an regular notification.
My intension is to build an node-red flow to push a doorbell notification.
Maybe someone of you built just that and can post an example?
Thanks a lot.
Could try this. This setup works for my partners Samsung though with DND which is the first script. I don’t actually use DND on my huawei phone, which is the second script. I think I added the delay because it was taking a moment to disable DND.
They are from the companion app docs
Delay
emergency_alert_roberta:
alias: Emergency Alert - Roberta Phone
sequence:
- service: notify.mobile_app_sm_n960f
title: 'off'
message: command_dnd
message: command_ringer_mode
title: normal
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
title: '{{ volume|default("16", true) }}'
message: command_volume_level
channel: alarm_stream
title: '{{ title|default("Ring", true) }}'
message: '{{ message|default("Ring", true) }}'
priority: high
ttl: 0
tag: '{{ tag }}'
group: '{{ group }}'
actions:
- action: alarm-arm-silence
title: Silence
- action: alarm-arm-disarm
title: Disarm
mode: parallel
description: Sends an emergency alert to phones even on DND with appropriate Volume
fields:
volume:
description: Volume on the device
example: 6
title:
description: Title of the android alert
example: Default Title
message:
description: Message of the android alert
example: Default Message
max: 3
icon: mdi:phone-alert-outline
No Delay
emergency_alert_bob:
alias: Emergency Alert - bob Phone
sequence:
- service: notify.mobile_app_phone_model
title: 'off'
title: '{{ volume|default("18", true) }}'
priority: high
ttl: 0
tag: '{{ tag }}'
actions:
title: Silence
title: Disarm
mode: parallel
fields:
volume:
example: 6
title:
message:
max: 3
Thanks a lot. I rebuild you automation on my system but the Huawei device is still not reacting to important/priority messages. Seems to be a problem with android.
make sure the app has proper permission to run in the background and any other power saving setting that the device uses. Every device is different so you may need to dig into settings. You need to make sure to follow the critical notification format:
