Since a few days (I think after the update from 102.x to 103.x) it is no longer possible to connect my Huawei LTE modem.
This is an HA installation on a Synology. The Huawei LTE modem is a B529s-23a.
And everything has worked fine.
Can anyone help me solve the problem or do you need more information about my system?
I always get the following error message. No matter if I do the Huawei integration via the frontend or the config.yaml.
[homeassistant.components.huawei_lte.config_flow] Unknown error connecting to device
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 416, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1344, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 306, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 275, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 400, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
chunked=chunked,
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
