Hello, I’m new to Home Assistant and English isn’t my native language. Please excuse any mistakes.
I’ve installed Home Assistant in a virtual machine on Proxmox, and I’m connecting to the internet through a Huawei B715s modem-router.
When I use the Huawei LTE integration, the connection to the router works, and Home Assistant successfully collects various data (such as SMS, current speed, connection data, etc.). Unfortunately, the integration fails whenever Home Assistant or the router is rebooted.
The only solution I’ve found is to delete the integration and set it up again to reconnect.
Here is the error that appears in the Home Assistant log:
Enregistreur: homeassistant.config_entries
Source: config_entries.py:551
S'est produit pour la première fois: 23:10:53 (1 occurrences)
Dernier enregistrement: 23:10:53
Error setting up entry B715s-23c for huawei_lte
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 404, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1058, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 419, in connect
self.sock = ssl_wrap_socket(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/ssl_.py", line 453, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls)
File "/usr/local/lib/python3.12/site-packages/urllib3/util/ssl_.py", line 495, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "/usr/local/lib/python3.12/ssl.py", line 455, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.12/ssl.py", line 1042, in _create
self.do_handshake()
File "/usr/local/lib/python3.12/ssl.py", line 1320, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:1000)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='169.254.100.156', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:1000)')))
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/huawei_lte/__init__.py", line 352, in async_setup_entry
connection = await hass.async_add_executor_job(_connect)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/huawei_lte/__init__.py", line 343, in _connect
connection = Connection(url, **kwargs)
File "/usr/local/lib/python3.12/site-packages/huawei_lte_api/Connection.py", line 32, in __init__
super().__init__(url, timeout=timeout, requests_session=requests_session)
File "/usr/local/lib/python3.12/site-packages/huawei_lte_api/Session.py", line 75, in __init__
self._initialize_csrf_tokens_and_session()
File "/usr/local/lib/python3.12/site-packages/huawei_lte_api/Session.py", line 169, in _initialize_csrf_tokens_and_session
response = self.requests_session.get(self.url, timeout=self.timeout)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 602, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 725, in send
history = [resp for resp in gen]
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 266, in resolve_redirects
resp = self.send(
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 517, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='169.254.100.156', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:1000)')))
I hope to make progress towards a lasting resolution of this issue and thank you in advance
