I added an Huawei router and now all devices connected to router are showing as device trackers. Is there a way to remove any of the devices added? I want to to set track_new_devices to false so I can keep the ones I want to track. The naming is quite confusing as well with some using MAC addresses and others the host name.
I know there use to be a known devices yaml file but I just started using HA, so I can’t see this devices in anywhere except the Customization page on UI.
This is how I did it for my netgear. By adding the devices list, it will only create device_tracker entities for things that match the MAC addresses in the list.
I put them in my secrets.yaml file just in case I want to use my phone MAC address in other things. Should it ever change, I only have to change it in a single spot rather than who knows how many later.
I didn’t realize I could add devices by mac address. At least I think that option is not on the docs. But yes, I have my configuration file similar to yours.
That’s a good option for me. But for the devices that I have now is there any way to delete? I even tried to comment the Huawei router integration and they’re all still listed.
Edit: you have a Netgear router. Devices are probable just a Netgear variable.
Any updates on this one in 2024?
I’ve just added Huawei LTE integration (via UI) and it set up 27 devices!
I don’t need to track my Shelly devices or other wifi devices that I have in my house.
Is there a way to remove all of them? Or even better. How to Remove (Disable) the device tracker in Huawei LTE?
