Hub otodo?
Good morning
I have several Di-o brand on / off actuators that go by radio frequency and connect to a hub, which in turn connects to the “otodo” cloud
The model is otodo hub-1
Does anyone know if there is a way to integrate it into home assistant ???
The HUB is a very cost-effective multi-protocols device offering the capacity to connect and manage existing and new devices in the house.
Prop. 433 MHz RF, 868 MHz RF,
Zwave, Zigbee, Enocean, Lora, Sigfox
Bluetooth LE
Wifi
Designed for CE and FCC certifications
Remote firmware updates
Hi, did you manage to integrate you’re otodo hub to home assistant ? I tried the same but with no success, so i used a broadcom rm4 to learn the rf command of my plugs and i created booleans to interact on lovelace. If you find a way to use it could you tell us :slight_smile:
Thx
