Hello, i am using HAOS on Proxmox and tried to connect my Huebridge and HomeaticIP bridge.
Hue has been discovered automatically, even after changing the IP, but the connection isnt possible by pushing the bridge button… same problem on homematicip bridge.
found the thread on this forum …
and some other threads, but no solution…expect using Homeassistant baremetal ?
my hue app on my mobile phone can access the bridges even from another vlan… is it really a problem of the proxmox bridges ?
for the moment my firewall allows HA access to everything …
You mention VLAN, so are the devices you try to discover and the HA server on the same VLAN?
If not then you might need to set up reflectors/repeaters/helpers on your network router, if they can support that.
