Hue and PS4 errors occur every 30 min
Hi guys,
For a while now I got two repeating errors. Every half an hour I get an error which is related to the custom component ps4. However this component works fine. The second error has something to do with the hue component, I think this error is related to this closed issue #13949. I hoped this would be fixed in 0.72.0 but it doesn’t.
The strange thing is dat both errors occur almost at the same time after exactly half an hour. Does this mean that the seccond error is caused by the first or is there a process that repeats every half an hour and caused both problems?
2018-06-22 19:30:08 ERROR (Thread-19) [pyps4.ddp] failed to send data using socket, timed out
2018-06-22 19:30:11 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.108
2018-06-22 20:00:09 ERROR (Thread-7) [pyps4.ddp] failed to send data using socket, timed out
2018-06-22 20:00:09 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.108
2018-06-22 20:30:11 ERROR (Thread-5) [pyps4.ddp] failed to send data using socket, timed out
2018-06-22 20:30:12 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.108
2018-06-22 21:00:11 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.108
2018-06-22 21:00:12 ERROR (Thread-16) [pyps4.ddp] failed to send data using socket, timed out
2018-06-22 21:30:11 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.108
2018-06-22 21:30:12 ERROR (Thread-3) [pyps4.ddp] failed to send data using socket, timed out
