I have a simple automation that activates a five minute timer as follows:
five_minute_delay:
alias: "Five minute delay"
sequence:
- service: homeassistant.turn_on
entity_id: input_boolean.enable_timer
- delay:
minutes: 5
- service: homeassistant.turn_off
The automation is called when a group of two Philips Hue lights are turned off by using the state commend from on to off.
It works, but recently I have noticed that it takes up to 30 seconds for the script to activate which is causing problems and I can’t work out what is causing the delay. I have read a few posts about resetting the Hue hub which I have tried but it does not seem to have improved things.
There are no errors in my log file that I have seen that point to failed connections with the Hue.
I have sort of managed to workaround the problem but it is bugging me that I can’t find the cause of the delay.
Can anyone suggest a good place to start to try and find my bug!
