I have just started on Home Assistant. I have a Raspberry Pi 3 model B and have installed Hassbian 1.31 on it. The only ‘smart’ stuff I have is a Philips Hue Bridge and 3 hue white bulbs. Going to http://hassbian.local:8123 I see the PHue configorator telling me to press the HBridge btn and then click the btn on screen. I do that and sure enough the 3 Light Bulbs show up, but in the home-assistant.log I get:
2017-11-03 14:04:44 WARNING (Thread-9) [homeassistant.components.light.hue] Connected to Hue at 192.168.0.2 but not registered.
There is a phue.conf which contains:
{“192.168.0.2”: {“username”: “bunch of letters & numbers here”}}
There is no devices file in the dir. I have wiped th SD and retried installing 3 times, same result every time. How do I get HA to “see” the Hue Bridge?
