Hue Bulbs appear twice on States, only one updating. Hiding does not work
I’ve written automations to monitor Hue bulbs and turn on or off none hue lights to match. The hue bulbs show up twice on my HA States page once from Hue and once from wink. The names are identical, but only the ones on hue seem to update. The ones wink don’t change unless I manually force one of them from the wink app. At that point the application works as intended. It appears that my automation looks at the non-updating wink version and therefore do not work. I am planning to contact wink as well to see why these lights are not updating. Meanwhile, is there a way to force them to use the Hue version of the light or do I need to remove the hue lights from my wink hub? Here is my application just in case:
‘’‘yaml
alias: ‘spotson’
initial_state: True
platform: time
seconds: ‘/5’
condition:
condition: and
conditions:
- condition: state
entity_id: light.MakeupOne
state: ‘on’
- condition: state
entity_id: light.bedroom_spots
state: “off”
- condition: time
after: ‘07:45’
before: ‘21:30’
service: light.turn_on
Given that both bulbs have the same name, hiding one of them in customize.yaml doesn’t seem to help.
Okay I rebooted both hubs. Maybe I should have tried that before posting but I didn’t think of it. Anyway things seem to be work for a few minutes but then stopped again. Definitely not fixed. Oddly enough the earlier, first instance of the bulb name was updating and not the second. Now the second instance is updating not the first.
