Hi.
I’m looking at moving my deconz setup to z2m.
Have added a few Philips Hue bulbs to test it, and I can’t get them working in HA.
Lights are added to z2m, all color options, etc. available.
They show up in MQTT, everything looks good.
When I add the light to Lovelace, it shows as being off, even though it’s on, and it does not show any of the color options. Just a brightness slider.
I’ve no idea what’s happening here.
Anyone encountered this?
edit: Just noticed I can’t control them from the z2m dashboard either. :-/
UPDATE:
Ok, so I have color and brightness sliders in Home Assistant, but no control over the device.
Various config files follow:
Mosquitto Broker 6.0.1
logins:
- username: myuser
password: mypass
customize:
active: true
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
broker: true
Zigbee2mqtt 1.22.2-1
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
user: myuser
password: mypass
serial:
port: /dev/ttyACM0
adapter: deconz
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: true
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
/share/mosquitto/acl.conf
acl_file /share/mosquitto/accesscontrollist
/share/accesscontrollist
user myuser
topic readwrite #
I’m hitting a dead end.
Any help much appreciated.
