I am trying to use a dimmer switch, connected directly to Home Assistant using the HA ZigBee integration, in order to control some lights via Mode-RED flows.
The dimmers show up in the HA automations area to be used, I believe this is the event montoring, however I can not seem to find in it Node-RED from any nodes. I’ve tried searching but all the other examples I’ve seen are either connected via the Hue bridge, or seem to have a switch entity attached to the dimmer (which I do not).
Any help appreciated.
