I have connected some Hue lamps and their corrosponding dimmer to HA via deconz. I have used the below appdaemon app for it:
import appdaemon.plugins.hass.hassapi as hass
class RemoteControl(hass.Hass):
def initialize(self):
if 'event' in self.args:
self.listen_event(self.handle_event, self.args['event'])
def handle_event(self, event_name, data, kwargs):
if data['id'] == self.args['id']:
self.log(data['event'])
if data['event'] == 1002:
self.log('Button on')
self.turn_on(self.args["lightID"])
elif data['event'] == 2002:
self.log('Button dim up')
self.new_brightness = self.get_state(self.args["lightID"], attribute = "brightness") + 25
if self.new_brightness >= 255:
self.new_brightness = 255
self.turn_on(self.args["lightID"], brightness = self.new_brightness)
elif data['event'] == 3002:
self.log('Button dim down')
self.new_brightness = self.get_state(self.args["lightID"], attribute = "brightness") -25
if self.new_brightness <= 0:
elif data['event'] == 4002:
self.log('Button off')
self.turn_off(self.args["lightID"])
That basically means that I can turn on the lamp via the dimmer and dim it up/down and shut it off. I am however missing the original functionality of the dimmer to change the color temperature when toggling the “on” button. Is it somehow possible to modify the turn on (1002 event) so that it just toggles between 3 different color temperatures - fx. 200,300,400? Or alternatively call 3 different scenes.
