Hue dimmers not reachable
Hey guys I’m struggling with hue and was wondering if someone has an idea how to setup the wifi and zigbee channels as at the moment I think both are kind off overlapping and ends in result of non reachable hue devices which is annoying if I can’t control my lamps with the hue dimmers . Any recommendations are welcome
I haven’t really run into this particular issue, but I use a WiFi Analyzer on my Android tablet that shows what WiFi channels are the most populated in my area and this allows me to use one that isn’t being used as much by my neighbors (who likely aren’t even aware of such things). This might be a place to start.
Here’s a link to the one that I use:
Thanks mate. I read a lot about this and WiFi ZigBee Frequences… I will change my WiFi to channel 1 and ZigBee to channel 25. Like this they are enough far away from each other . This might be a solution…will post the result
Well after changing the channel to 25 on the hue hub the dimmers only work partially and some bulbs also I might will have to reset all hue devices which dont work
