I’ve just installed my Hue Ensis lamp through Zigbee2MQTT. The lamp has both a light shining on the top and the bottom, but it seems I can only control the bottom lamp.
Anybody know how to be able to control both top and bottom separately?
@lts39 did things work out in the end? I’m thinking about getting an Ensis, using it with zigbee2mqtt, but I haven’t found any solid confirmation that you get two lights in Home Assistant (top&bottom)…
I just changed my Ensis from HUE to z2m.
In HUE I had two different lights LCP-01 and LCP-02 for lower and upper light.
So when you pair it with z2m you should also get two separate ones.
My workflow for the HUE lights is as follows;
You should indeed get two lights, but somehow I can’t find confirmation – and as this is one of the very few places on the internet saying anything about an Ensis being used with z2m… And it says only one light shows up. Hence my curiosity
You get two separat lights… i just added it to my HA via Zigbe2Mqtt.
Finally pulled the trigger and got the Ensis, at a nice discount
Akcapak was right, two lights (or rather: two separate devices) in Z2M and in Home Assistant.
