Hue Go Light always turns on blue
I have a Hue Go 2 that’s appearing in Google Home through Home Assistant as a light. The issue is that whenever I ask Google to turn on the lights in the room, the Hue Go defaults to blue.
If I turn the Hue Go on through Home Assistant, it works fine, turning on with a warm white or the last color used.
I’ve checked for any settings in Hue, Home Assistant, and Google Home but can’t find anything that explains why it defaults to blue.
Can’t even seem to work out where the issue is originating from. Is it due to Z2M, or Google Assistant, or HomeAssistant?
Any ideas?
From the sounds of it, its the way the connection between Google Home and Home Assistant is handling it that is the issue if you are able to use it without issue directly in Home Assistant.
You may need to setup a default color and temp that they turn on when used through it to counter it until it works as it should without.
Where would I set this up?
