Hi all,
when I move a light to another hue room via the Hue App, this does not get updated in HA, the light stays in the old room=area (auto generated areas in HA from hue rooms)
I started with HA end of last year and I am on the latest version, so the hue rooms feature generally works very well (enabling etc.)
I tried multiple times:
-Hue Bridge Cleanup in Hue App
-Hue Integration Reload in HA
-HA restart
-Hue Bridge Update
nothing helps.
→ For example renaming a light in the Hue App instantly gets updated in HA.
I could manually assign the correct area in HA, but is there no way this action of moving to another room gets also updated in HA?
As the manual change is kind of a manual overwrite and the correct area from the hue integration would be of course better.
But of course if that is the way I will do it, maybe light → room assignement is only done once initially?
Big thank you in advance.
