Hue issue after upgrading to 0.43.2
Hi guys,
Since upgrading to HA 0.43.2, my Hue lights are not showing up anymore. The below message error shows in the log :
17-05-03 09:44:33 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 155, in _async_setup_platform
    entity_platform.schedule_add_entities, discovery_info
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/light/hue.py", line 123, in setup_platform
    setup_bridge(host, hass, add_devices, filename, allow_unreachable,
NameError: name 'allow_unreachable' is not defined
Any help to resolve this issue would be greatly appreciated!
Gio
dont know if this can help but after last update the discover option is not working for me and hue lights,ios,players, and all devices that were added in discovery mode so i had to add them manually and disable the discovery mode because it was giving me an error so that is working for me at this moment
I tried disabling the Discovery mode but I have the same issue. Hue lights not showing :sweat:
What’s your hue config look like in HA? Here’s mine - working fine in 0.43.2:
# Hue API
light:
  platform: hue
  host: 192.168.1.151
  scan_interval: 10
  allow_unreachable: true
  filename: phue.conf
Here’s mine:
# Philips Hue lights
light:
  platform: hue
  host: 192.168.1.27
  allow_in_emulated_hue: false
  scan_interval: 10
  filename: phue.conf
Are you running a physical hue hub or an emulated one or both?
What if you did not set it up in the config just let HA discover it automatically? That’s how it is for me currently and it is working properly.
Also, you mean 0.43.2 right? That’s the current version.
Hmmm…Here’s my experience. I was running .38.2. Upgraded to 43.2, HA doesn’t see any light. I then added the below and HA sees the lights (discovery is still in the config file). I do have the actual bridge. Previously in .38.2, I did not have the lines below in config.
light:
  platform: hue
  host: x.x.x.x
Both. I run emulated hue so all devices are visible to Alexa and in conjunction with Homebridge for Homekit (iPhone). I have a physical hub (philips hue 3rd generation).
Everything used to work prior to upgrading to 0.43.2. I tried downgrading as well but the error message in the log is aways the same
I tried to just allow HA to discover the lights but no luck. Yes, i meant 0.43.2, apologies to everyone for the mistake (title updated)
Tried that as well but still no Hue lights showing in HA.
light:
  platform: hue
  host: 192.168.1.27
This is the full log:
17-05-03 22:37:29 WARNING (Thread-1) [homeassistant.components.emulated_hue] Alexa type is deprecated and will be removed in a future version
17-05-03 22:37:32 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
17-05-03 22:37:36 WARNING (MainThread) [homeassistant.setup] Setup of binary_sensor is taking over 10 seconds.
17-05-03 22:37:37 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
17-05-03 22:37:38 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
17-05-03 22:37:41 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform ring is taking over 10 seconds.
17-05-03 22:38:54 WARNING (Thread-7) [netdisco.ssdp] Found malformed XML at http://192.168.1.29:9080: status=ok
17-05-03 22:38:59 WARNING (Thread-7) [netdisco.ssdp] Error fetching description at http://192.168.0.254:49152/wps_device.xml
17-05-03 22:39:02 ERROR (Thread-10) [homeassistant.core] Error doing job: Future exception was never retrieved
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/google_travel_time.py", line 113, in run_setup
destination, options)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/google_travel_time.py", line 146, in __init__
self._client = googlemaps.Client(api_key, timeout=10)
AttributeError: 'module' object has no attribute 'Client'
17-05-03 22:39:02 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/light/hue.py", line 103, in setup_platform
host = urlparse(discovery_info[1]).hostname
KeyError: 1
17-05-03 22:39:03 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
KeyError: 1
I’m afraid I have no experience to draw on with the Emulated Hue component. You might want to look at these github issues to see if something is related. The link below will show only emulated hue issues.
Thanks anyway @rpitera. I don’t think however that the issue is related to the Emulated Hue component since that works for all my other devices (switches, sensors, media players). They all in fact work fine with Alexa and Siri. I think it’s specifically related to the Hue Bridge.
did you solve?
Hi @anon35356645, apologies for the massive delay in getting back to you, I have been super busy with work lately. I did eventually solve the above issue after physically resetting the Hub.
